As most of you already know, the Explorer's front timing cover does not have the boss to drill a hole for front dip stick. But it does have enough material in the same area behind the front crank sensor. I believe I need to drill an 11/32" hold for the dip stick. If I drill this area, the dip stick will be little higher.
I don’t want to swap the timing cover because I have complete serpentine front accessories for it.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
<o:p></o:p>
Has anyone drilled & mounted a dipstick on Explorer front timing cover ???<o:p></o:p>
<o:p></o:p>
Thank you,<o:p></o:p>
<o:p></o:p>
Waid<o:p></o:p>
Discussion Starter · #2 · (Edited)
Here they are side by side. As it can be seen, the normal front sump 289/302 dip stick is little lower than the Explorer's. I can always cut little off from the dip stick tube to lower it a little.
I have several Explorer's timing cover so I have few to play with in order to get it right.
Waid
Banned
never done it.
when you do drill the cover, would help if you have a cover with dip stick .
that way the drill angle could be adjusted so the in pan outlet is in the same area
Nice idea Waid. How is this working out for you?
Did you keep the Explorer crank sensor in place with this modification?
