HI i have a 87 ford F150 that needs a set of head, the one's on it now have 2 burn't valves and use a little oil throught the valve seals, they have also seen temps over 270 degrees 3 times (not good!). Anyway i just put a new set of heads on my 89 GT 5.0 and the old heads are perfect and i want to swap them out into the windsor. Will it work and what do i have to change if anything. The widsor is stock except for aluminum intake and a small small cam. But i just rebuild it and it needs heads. Thanks for all the help.
One thing you will have to do is make the head bolt holes bigger from 7/16 to 1/2. Push rod length mite be close but you would still have to check it. Instaled hight mite be diffrent along with valve stem tips.
