I just got the tranny bolted in last night with the new valve body. Anyone running one of the TCI reverse manual valve bodies? If so how do you like it ? Anything to watch for ? Engine braking? Anything you dont like?
I'm running a C4 with 6 red clutches in both drums and .030" clearances in both drums , rigid kevlar bands, "A" servo with small rubber ring removed and servo modified and hole pugged per the TCI instructions, 4000 stall converter, 6 pinion planetary, fully rollerized except the front take up thrust, hardened shaft etc.
