I'm kicking around a project idea to swap a Boss'9 into a
'94 & up Mustang like Ford had Roush build.
Any advice from someone who has done it is much appreciated.
It will be an EFI/5 speed Tremec street car.
If you can afford to build a boss 9 then the rest should be cake. The DOHC cobra motor is about the same width. And weight i think.
Good luck!
Good luck!
Not even close to the same weight.
I'd seriously like to step up to a new C & C Perf. version aluminum block and heads, then the weight should be close, maybe thats what HotRodPinto was thinking...
