hey guys im building a stroker and im still trying to decide on heads suggestions would be welcome i was going to go with the trick flows but i have read that with the srp pistons they wont work i have srp flat top pistons i have herd you can run them it just has a big limit on your cam lift have any of you run a setup like this
thanks jeff
cam lift isnt the determining factor in clearance issues, its the timing events and especially the overlap which causes issues, when the intake valve is fully open at max lift the piston is already traveling down the bore drawing in the intake charge. Any head will work, do a mock up check your clearances, if needed, have them cut and the balance the rotating
yeah i would rather just know that they would work rather then have the pistons cut and rebalance it ill have to do some more research
any other head suggestions
thanks jeff
You can run trick flow heads with the srp pistons as long as they are the street heats, and that would be a much better head to go with.
