I am in the process of upgradeing my AOD trans. I have a 1990 trans and am using the stamped steel drums and wide ratio gears from a 1999 4r70w trans. When tearing down both transmission I noticed a slight difference in the pumps. Can you use the newer style 4r70w pump in an AOD? If you can is there any advantage to doing so?
No. Like said above, use the AOD pump. I did this twice on my Fairlane & Comet.
