AOD, Fresh rebuild works in reverse, will go in drive but in about 10 seconds it stalls engine. A few days ago in didn't stall engine when put in manual first range. Today it stalled in manual and drive ranges, but not in reverse. Took valve body down, no gasket issues or debris in pan. Any advise would be appreciated!!! Chris
Try an extra ground. I put an extra from the flywheel dust cover to the car unibody (any where). This fixed my problem of not going into od (4th) unless I went to neutral first.
