1 - 9 of 9 Posts
Does anybody know roughly how many HP an AOD takes from and engine through parasidic power loss to the rear wheels?
Thanks, Chris.
More than a C4, less than a top loader 4spd and less power than a C6.
Paul
Banned
Appx. 50HP right up there with the C-6, C-4 is about 37HP. Lowest is a Powerguide at 25HP. That's from the factory. Rollerized bearings and other mods drop that down fast.
Well, thets less than I expected. I was thinking 100 or so for some reason.
Thanks, Chris.
Banned
Manual trans loss, 3HP on a bad bearing unit. Usually 0 loss. That's the big advance they have were as the auto multiplies torque thru it.
Well it's physically impossible to have a meshed gearset and bearings have 0 HP loss but it should certainly be low...
MM & FF did a T5 test years ago and it was 18HP at upper rpms... would guess the Toploader is anywhere from 15-25HP loss.
power loss
Powerglide_____18 hp
TH-350________36 hp
TH-400________44 hp
Ford_C-6______55-60 hp
Ford_C-4______28 hp
Ford_FMX______25 hp
Chrysler_A904__25 hp
Chrysler_727___45 hp
"AOD and FMX share the same size internal components.
Even with the extra gear the drag is slightly higher than an FMX, which is a tad less than a C4. "
this from ford transmission forums
hope this helps
<font size=-1>[ This Message was edited by: thekrazykat on 1/3/07 9:46am ]</font>
1 - 9 of 9 Posts
