A friend of mine has a 93 GT with an AOD. He bought the car used and has no idea what has been done to it but I've riden in it and its healthy. I would guess that with traction it should run mid 13's or maybe a bit better.
He blew the overdrive out of the AOD that was in it so somebody swapped in another stock AOD(not sure out of what) for him. He then noticed how harder it shifted with the original tranny so I told him somebody probably had put a shift kit in it. He has already blown the overdrive in this second AOD and the last time I rode with him I noticed it is already slipping when he hits second gear now. It won't be long before this second tranny is totalled too.
Is this just too much for the stock AOD? Are all the AOD's the same or are some better than others? If he takes his original tranny to a rebuilder are there some simple things that can be done to build it up so it will last? I told him not to try and hit the overdrive again going 100 with the throttle wide open because it might be a bit too much strain on a stock AOD.
