1 - 8 of 8 Posts
Bendstens Transmissions on the internet sells a convertion kit. I used their adapter to convert my 1966 thunderbird, with some modifing of course, due to what I converted to. Call them or go to their website
http://www.transmissionadapters.com/
390 fe Tri Power Holleys
T45 5peed, Short shifter and Spec Ceramic button clutch
4:11 equa-loc (posi) 9" Large bearing G casting Case.
Digital Gauges and Speedo
Best of luck in the swap. Aod's can be difficult to setup due to the senitive cable settings. Alittle does a lot!!!
<font size=-1>[ This Message was edited by: casscomputers on 5/16/06 4:29am ]</font>
On 2006-05-15 04:45, strtcar wrote:
Anyone do an C4 --> AOD swap in an early mustang? Im thinking about doing it in my 67. What kind of tricks are needed to do this? Any donar years to look out for?
Richard
Lot's of postings here and other sites on the conversion.
Check out the search feature...
You'll need a different mount (National Parts & Drivetrain)
Tranny? Buy a good one. 89 and up. Make sure you a console shifter style tranny -- not a column shift.
You'll need the proper TV cable setup and carb bracket.
New cooling lines will have to be bent up.
Nothing hard -- just details.
· Banned
Make sure you get teh convertor for your flexplate's bolt pattern, 10.5 or 11.4". C-4s are normally 10.5. The AOD will bolt up tothe engine just as the C-4 did. As said earlier TV cable, crossmember and speedometer details. Alon with the cooling lines. DO NOT start the engine up and run the trans until you have the TV cable setup. If you try and drive it, you'll burn the trans up fast. You'll need a pressure gage and the adjustment info. Any trans shop can tell you how's it's done and it's actually very easy.
Doing this on my '69 over the summer. Got the 164t flex plate off ebay, got a good AOD, still gotta get the trans mount and yolk. Like previously stated, pay attention to the details more than anything else. Nice to buy stuff new if you got the cash, but patience can result in up to 75% savings on the cost. Cheers
1 - 8 of 8 Posts
