I have a 88 5.0 and AOD that I have installed in a 65 Galaxie Convertable.
Everything seems to be ok(TV pressure, fluid level), but have no reverse. When I click the lever on the trans(car is on jackstands), into reverse, it wants to go into forward gear.
I did change the shifter lever(using a lokar cable) and put a washer btw the lever and the tv lever to keep the tv lever from binding.
Anybody got any ideas why I don't have reverse? I don't know if the trans worked ok before(bought it used, out of the car).
On 2006-06-27 11:14, dodgestang wrote:
You sure you are in Park?
Your shifter may say park, but it sounds like neutral if you go one click and get a forward gear.
I agree, also nice to see another cleveland floating around out there, good stuff
I know it is in park, cannot move the driveshaft. It will click to all the different positions, but no reverse.
As I stated, I shimmed the tv lever off the shift lever with a thin washer to keep it from binding. Could this be moving something in the trans to keep reverse from engaging?
