I usually don't post but just read alot but need some help. I bought a monster
transmission and I am trying to hook up the TV cable from lokar . There instructions tell about in N at idle there be 0 psi insert there block and it should be about 35 psi. The new tranny has 55 psi at idle in N. So i believe
that this must have the constant pressure valve body like TCI makes. I have talk to both company a few time and I still can't get a straight answer from either on how the cable should be set. Has anyone had experience with this setup. Monster tranny tell me to take it to a shop but they won't set it because it is not a stock setup. I am using a edelbrock carb. Need help thanks Mitch
