Maybe a dumb question but ill ask anyway;
Do I torque up high tensile ARP bolts to the the normal ford specification or are they supposed to go to a higher torque setting??
Thanks,
Martyn
<font size=-1>[ This Message was edited by: martynUK on 6/12/06 5:08am ]</font>
it depends. if you use oil or arp lube on the threads. most of the torque values for the bolts in my 408 were a little different than a ford manuel. give them a call or go to their website, its really good.
almost all arp bolt kits & stud kits come with their own torque specs. usually if no specs then use oem specs.
I would use arp moly lube and their specs
