I was told by a buddy of mine that when using ARP rod bolts that the torque is different then when using factory rod bolts. Is this true? I have my Cleveland all together and ready to install the oil pan and have the rods torqued to factory specs using oil as a lubricant on the threads. Am I in trouble?
Blue Fastback
You should have received instructions from ARP with the bolts. They recommend measuring the rod bolt stretch with a tool. If you decide to check with a torque wrench, the torque values vary based on type of lube used. I'd call ARP and request torque numbers for oil.
Here's their website...
http://www.arp-bolts.com
Here's the torque table (general)...
http://www.arp-bolts.com/pages/tech/images/fasttorq.pdf
Here's the torque table for rod bolts...
http://www.arp-bolts.com/pages/tech/images/rod_bolt.pdf
Good Luck!
Mike Burch, 66 mustang real street
302 4-speed 289 heads, 10.63 @ 129.3
http://www.geocities.com/carbedstangs/cmml_mburch.html
http://www.fortunecity.com/silverstone/healey/367
<font size=-1>[ This Message was edited by: n2omike on 4/2/02 7:58am ]</font>
first a strectch gauge is for using as a referance for a non torgue bolt then after you torque it then when you take it apart later like at the end of a season check it again and see how much strectch you have to from the new bolt apr has set limits on them. just my .02
Alan
i kinda recall the ARP instructions when i was putting my motor together saying that if you dont have a stretch gauge, then torque down and loosen the rod bolts 3 times. apparently my machinist had already done this so i just torque them down using the ARP lube and ARP specs.
