Finally getting the car right and on the way to work this morning, it flared 2-3 gear really bad. I'm at work and dont want to drive it home before I try and adjust it. I know the adjustment for 1-2 gear is on the drivers side, is the intermediate band adjuster the one right next to the H servo?
This is the first time its ever done it.
Tracy
The intermediate band adjustment is on the drivers side.The "h" servo is on one side of the band and the adjuster on the opposite.The low reverse band ajustment is on the passenger side.Good luck crawling under the car after work.
Update. Pulled it into shop at lunch and adjusted it. Took her for a spin and it didnt do it again. I'm also thinking I need to check the cable from my shifter. It may have not gotten all the way in gear. I noticed when I squeeze the shifter to go into 3rd it stops so far then when I let go it will actually push ahead a little further. Maybe the gate is toast.
Let you know
Tracy
