The 1984 boat I have has transmissions that require Dexron II. Is this the same as Ford's type F?? It seems I read somewhere that type F will work....what do you guys think??
Thanks,
Cobrajack
Dextron/Mercon & all the other later trans fluids are slightly different from type F. I almost always change to type F as it makes shifts a little crisper, when I don't use synthetic ATF.
