I didn't dyno this engine. It should be a bit stronger than the 331 I have in my Mustang. It has run a best of [email protected] The intake is a Victor Jr. Lightly port matched.
The cam is from Ultradyne. Solid flat tappet. Lift is .585 as measured at the retainer with 1.6 rockers. The duration at .050 is 248. Lobe separation is 108 and the centerline is 102.
They grind some mean little cams for the small block Fords.
I used the horsepower calculator on the front page and come up with 402hp at the flywheel and 342 at the wheel. It doesn't sound like much but its only got 9.9 comp., and it has only had 87 octane gas run in it.
This latest engine has 10.2 comp., and more cam. Maybe 355hp to the tire. The et slip don't lie!
Mike read the thigs in the attn.sweet venom.What do u think bout those cam specs.run them and se what type of horsepower u get.It is a crowler cam 15322 what do u think.
