1 - 13 of 13 Posts
There is apparently a metal or brass pipe looking piece that's supposed to go on top of the check ball in the carb. I don't recall my carb having that, but I may be mistaken. Do you know if it's required to have that metal sleeve over the check ball? Sorry, this is my first carb rebuild
63 convertable
it is needed. it makes the pressure be high enough to spray into the venturi. without it the acc. pump will dribble
Alright. Thank you. There was a brass piece that came with the kit but it is entirely too large to fit in that hole
The metal piece on top of the ball is supposed to be a small solid metal rod.
It acts as a weight on the ball.
Its possible not all carbs use it. It “might” be ok without it.
I don’t think it comes in the repair kit.
There is a really large one that came with the kit, but unfortunately it's too large for this application. There is a screw that runs through the Venturi with a hollow end, the lead weight is way too big to fit in the hole of the screw, Therefore I cannot install the venturi using that Weight. Would you guys try to run without it or try to find that weight. I'm borderline about to put this 2 barrel on a shelf and just get a holley 4 barrel
I think the large brass part you have is actually item 65 in the exploded view: Motorcraft 2100 Exploded View - Mikes Carburetor Parts
Item 8 is the part you are talking about, it may be fine as is, it is to stop fuel draining back to the accelerator pump so you get a good pump shot of fuel (and not air). if you fill the bowl up with fuel and work the throttle you will be able to see if the accelerator pump is squirting properly or just dribbling out with out the check rod.
you can get a new check rod here Holley 1970 Carburetor Float Pin
That shows to be for a 4 barrel, but it says it also fits 2100 series, so I believe they would be the same. Mine does have an 1/8" inlet in the screw
Yeah, the kits don't come with those, so you should always keep track of that and don't lose it! I have enough cars that run these carbs that I've amassed a bit of a spare carb parts stash from some parts-carbs I've acquired over the years. Little stuff like those can easily be lost. You can make one of those out of a nail, by the way. It just needs to be heavy enough to hold the check ball down and skinny enough to fit in the aperture of the screw.
Discussion Starter · #11 ·
I definitely would have done that, but Ive already ordered one from Mikes Carburetor. And yes, I normally dont lose stuff like that, but my stepson decided to wrap up everything in a towel while I was working and put it in my toolbox, so that nothing got lost. Im not sure if it originally didnt have one or if he possibly could have lost it on accident.
Best go with stock piece. I once used a nail but it would get stuck at the top of the tube, took a while figuring out what was wrong. Still, sometimes you have to improvise with what's in the kits. The gasket for my booster set was too thin, realized that when testing and they wouldn't squirt properly. Same thing with the PV gasket. Trust, but verify!
Discussion Starter · #13 ·
Thanks! I ordered the one from Mike's Carb and finished the rebuild today. Runs great
1 - 13 of 13 Posts
