Hello,
because of local laws here in Germany, I had to change headlights and wire the yellow positioning lights, which are in the front flasher in stock setup, to be white and in the headlights.
Was pretty easy with the given cables. Removed the according cables from the turn signal plug right before the housing and re-routed them to the headlights (they have a second bulb in them), took ground from the horns and that's it.
Now my turn signals flash to fast. But what's even worse...only the inner sequential turn signals on the rear end are working. Could it be, that I have to put a resistor somewhere or what might be the issue?
Best regards and thanks for your help!
I contacted Vic, who is the founder of this site. He helped me really great. I ordered a flasher can. That should fix the problem.
