1 - 9 of 9 Posts
Trying to track down the idle eze adjuster needle as in this article below .My BG carb is drilled for this but plugged and i need the idle airflow but dont want to drill the butterflies.....Anyone know where these might be available .BG aren't real good at replying to emails even though they promised 2 day response.
http://www.gnetworks.com/v4files/barrygrant/IdleEze%20with%20Images2%20(3).pdf
as Found on a chevelle forum:
I just got an e-mail from the Barry Grant tech dept. and the retro fit is P/N 121243 ,but it's the whole baseplate is what I get from message.Not what I was wanting to hear
If you have a Race Demon baseplate that has a bleed in it, you can purchase an Idle-Eze assembly through any Barry Grant distributor it is P/N 421393. You would just have to drill out the base of your main body (below the air cleaner stud) if yours is not already drilled through.
Thank you very much.I'm on it.....My carb is a King Demon and has a plug...
<font size=-1>[ This Message was edited by: gregaust on 9/12/06 11:54am ]</font>
Ok not much luck...Where is my best place to purchase the ..P/N 421393?
Another question. Is it possible to get a BG 2 port reg repaired? I have a new one that failed after 20 mins run time.
You can order the 421393 through any Barry Grant distributor. As far as the 2-port it can be repaired, however due to the way they are assembled they muct come back to us for repair.
20 minutes of run time??? Shouldn't that be a warranty issue?
I would like to think so but anyway at this stage i just want to get it fixed.. Do i send the reg to BG and if so where or who do i address to??? Sorry for the questions but way over here it is hard to get any answers.. Maybe a PM with the details would be much appreciated.
I'll check out the 2 distributors of BG here in Oz today for the 421393 and see how i go.
Thanks again TECH for you help.
<font size=-1>[ This Message was edited by: gregaust on 9/13/06 5:37am ]</font>
1 - 9 of 9 Posts
