I have purchased the Moroso Battery Relocation Kit with kill switch.I have been told to simply run the positive cable to the power distribution box next to OEM Battery location.Is this correct?
I would run the positive cable to the same connection that is currently used. Which I believe is one side of the starter solenoid.
Make sure you clean down to bare metal where you are going to attach the new battery ground wire. Also, while you are at it, remove and clean the engine ground wire. Cleaning both the wire lugs and the places it bolts to the engine and body and then reattach it.
