Good morning Galaxie group. I am going to relocate the battery to the trunk and I am wondering if anyone out there has done the same and can answer a few questions.
1965 Galaxie 4-door sedan.
1.) what gauge wire and solid or stranded wire to run the 15+/- feet?
2.) any routing suggestions, kill switch and terminal connections. Any recommendations?
3.) has someone found a good kit out there and did you still use the same battery hold down tray and bolts?
I assume the solenoid stays under the hood so I don’t have to relocate all the wires.
Thank you in advance.
