21 - 24 of 24 Posts
Clevelandstyle. How's that drum going? Can i ask what sort of interference fit or how many thou interference did you set up the section you pressed on.. Is it just loctited on?
Discussion Starter #22
The drum is holding up well. I've done another one for a buddy who wanted to try it too. So far so good. I think it's a winner.
I think I had about .001" interference. I used loctite but I don't think it's needed since the ring can't go anywhere in the stackup.
I'm going to give one a try myself. Do you think just mild steel would be ok ? Since you used tool steel or should i look to a better material..Thanks for your help.
Discussion Starter #24
Mild steel should work fine. I only used tool steel because I have access to lots of it.
21 - 24 of 24 Posts
