On my 1961, only the driver's door P.W. works. I pulled the pass. door panel and found I have power but one of the wires does not conduct from the main switch. I pulled the pass side motor. It test good but only goes up when hooked to harness and lacks power to rase window. My guess is a bad wire or disconnected somewheres. Before i go pulling the driver's door panel or trying to get up under the dash around the pedals, do they have a standard place that I can find the connectors in the power window harness? I have power to all switches and they are all good.
