1 - 8 of 8 Posts
I'm putting a ZF 5 speed in my F150 that originally was in a F250 5.8. I'm picking it up on Saturday. Before I walk away with it, I'd like to meausre and make sure they are not sticking me with a 460 or diesel sized transmission. I don't have a spare block or bell around and would like to know the dimensions acoss for the 6 bolt holes. See picture for dimensions A, B & C. These dimensions are for a small block 5.0 or 5.8. Does anyome have these readily available?
Thanks!
Doug
1966 Fairlane 390/C6
www.fairlanet.com
<font size=-1>[ This Message was edited by: fairlaniac on 1/19/07 10:19am ]</font>
Thanks but no. I need the dimensions in the picture. I just want to make sure the salvage yard has a SBF pattern on the ZF trans and not a 460 or diesel pattern.
Give or take 1/32" or so:
A= 5 1/8"
B= 13 1/2"
C= 16"
Measured off the back of a 89' 351w.
Dennis
65' STANG, 3160 lbs
393W NA, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, 236/561 Solid Cam, 9.6CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 1/19/07 7:27pm ]</font>
Dennis,
Thanks! Thats what I needed.
Where in "Amish Wonderland" are you from? I'm in NE Lancaster County (Denver).
just print and take that pic w/ u, there's an obvious difference, if you have somethin to compare compare it to, 351m-460, is wayyyyy taller....just my .02
1 - 8 of 8 Posts
