just wondering if someone could answer this? Will a c-6 tranny from a 400 bolt up to a 390? It would save me from rebuilding one!
You know, you could take the guts out of one and swap them into the other if you were really needing to get by on the cheap.
Greg
I thought of that too I guess the reason it is coming out is cause when I get the truck hot ( 20-25 miles or more) it starts pouring fluid out of the pump area but if it cools for a day or so it seals again and short trips it won't leak, I put a new converter seal in when I put the truck together and it has done this from the start, so I don't know if the pump gasket is cracked or what.
