Does anyone make a 157 tooth bellhousing to bolt up to a pan fill tranny (so it bolts to the case) yet?
It would be the best of both worlds.
You can do that anyway.Just use some longer pump bolts.Only thing is the larger panfill flange sticks out a bit ,but it will work ok..
No, thats what I am doing. I mean a 157 tooth bellhousing that bolts to the case, like the 162 does.
That way you get the added strength, and save space.
Did that come out clear as mud??
