I was under the car measuring so I can make my own caltracs when I noticited that the first part of my right rear leaf is starting to bow the wrong way. I only have 5 inches between the front spring eye and the second leaf. Between where the second leaf ends and the spring eye is where it is bowed backwards. If I add the caltracs will this be ok or should I replace the springs? The rear doesnt sag otherwise.
Tracy
I have the same problem with my springs. I plan to install the cal tracs anyway, and maybe the springs will bend back into shape.
Good luck,
Greg
