What engine gasket set do you FordHeads recommend for an 5.0 engine rebuild? The block is in the machine shop and the reciprocating assembly is there too getting balanced. In about one week I have some assembly to do. Could use some solid advice here. Running a 331 normally aspirated w/TF Track Heat intake, TF alum heads and about 10:1 compression.
