Hey Guys,
I posted a question in the C4 forum, but thought many of you might be in the same boat as I am. The 63 is just about running, but I need to get a good trans cooler for this Texas heat.
The car is a 63 with a 514 crate engine and a C6 with reverse manual valve body and an Art Carr 3800 rpm stall converter. I plan to use the car a few times a week on the street, and it will eventually see strip duty once the trans brake goes in after I build up the rearend.
What have most of you found to be the best trans cooler?
Thanks in advance for any help,
Dave
a big one.... i bought the biggest one the local parts store had on the shelf... better safe than sorry
Pick up a KL21 cooler...TruCool.
Check your local transmission supply houses they should have them. They work Great.
