Just make sure they are clean clean clean...Did I mention clean?..Use a degreaser and a power washer with hot water(car wash)..After that use a good high heat rattle can of your favourite colour...
Clean the crap out of them, then take a small butane or propane torch and HEAT the heads up until you see the moisture leave the head, no hotter than that. Then paint them. The paint really adheres well after that.
I used a can of automotive engine spray primer (might have been Duplicolor brand) before I painted my heads/block and I am surprised how well they have held up after several years use.
If the heads are out of the machine shop use some brake parts cleaner to remove any oil film and blow them dry. Do not use carb cleaner. You can buy high heat primer and paint for engine blocks. Keep over spray to min.
yep me too...
duplicolor , any color of choice metalic or solid...
then i put clear engine enamel over that....
gives it a nice durable shine , also makes it easyer to clean/wipe dirt and grease off...
I guess I left out some important info....it's just the heads and they're from the machine shop so there not dirty or greasy at all. I've got plenty of brake clean but will buy some clear for that added touch. I'll also use a propane torch to heat the moisture out of them too.
I thought about that so did wait a bit, no gas or explosions! LOL! I got them painted and now waiting for them to totally dry before I move them and take some pics. I'll post the pics under my other post on Rickracer 289 hi-po heads. There not hi-po heads but almost as good for a mild build cruiser.
