What are the specs for adjusting the front disc bearings on a 71-73 Mach 1? I looked in my manual and it gives the procedure for a Mercury with front discs but it didn’t specify whether it is the same for the Mustang. It says to spin the rotor and torque the nut to about 25 ft/lb, then loosen the nut a half turn and retorque to 10 ft/lb. I just want to double check.
