901 - 906 of 906 Posts
Slick looking setup Fat64.....But ya got it bolted to the wrong side of the car!!!! lol
Here,s another combo using the vette M/C to mess with your heads.
4 wheel disc brakes. Fronts are '71 Galaxie. Rears are local aftermarket.
M/C was sleeved down from 1" to 7/8".
M/C to prop valve lines have been reversed so its back chamber to front brakes. Custom piston.
After reading about about DanVs and Raggarens problems, I have my doubts if the system will work in my car:)
Two questions:
Where to look at the front caliper to see if its 499 casting?
Is it possible to test the caddy rear caliper if it has a faulty piston and caliper BEFORE they are installed?
Discussion Starter #903
Mine had a large 499 cast into the back of the caliper housing. You can't miss it.
But that might not necessarily mean anything. Maybe mine were just from a bad batch of castings, and most a good. Afterall, they have sold many of these kits.
Best of luck.
