In process of doing the Granada swap on the 63Galaxie using 78 T-Bird spindals and 68Mustand MC. Ford adjustable proportioning valve should be here early next week.
For my front brake lines, do i need to bring them togeather using a block valve(?) and then just run one line to MC? Only one line can go to the MC so i'm assuming this would be the way to do it, just not sure what the part is called??
Can anyone give me recomendations on how i should run these lines for the front? I realize it will be all custom since i'm doing it.
Rear brake line comes up along frame by gear box, do i just run this line to the firewall were the adjustable PV will be and then run the line from it to MC?
Kevin
Kevin
