i really want to put front disc brakes on my front end. new kits cost anywhere from 1000 - 2000 bucks. is there a junkyard solution that i can do to get disc brakes off a junkyard car and do a transplant? i got a 4.5 inch bolt pattern as you all prolly are well aware of and drum brakes all around. any makes models years etc of donor cars would be helpfull or should i just start saving and cancel christmas
Pretty much any car from the late sixties to late seventies will be good, prime ones bieng 77-79 t-birds and some torino's from 74-79? maybe? I went with the 78 bird and everything went smooth as far as bolting it to my 64. I haven't completed but am sure it'll be o.k. A booster master cylinder donor would be a early eighties crown vic, a direct bolt on if I'm not mistaken. Cars to stay away from, but will work are very large Lincolns and such as they have 5.5" bolt circle. There were a few cars that had that. I'm curious to know if early eighties crown vics would be a source for everything, especially on a 65? They called them LTD's but made six billion of them, not very limited so finding one may prove easy. Try them for everything.
You will need new wheels (after market of off of the disc brake car) for the front of your 65 as the drum brake wheels have a smaller diameter hole in the middle of the wheel compared to the larger disc brake hub.
I used 72 Torino spndles and disc brakes on my 66 Galaxie 500
I just bought a disc conversion for my 64 for $399.00,it uses your exsisting spindles.It comes with everything but the master cylinder and proportioning valve.I got it from a place called "Rod and Customs".
It aint braggin if you back it up!!!!!!
<font size=-1>[ This Message was edited by: 347LX on 6/13/06 7:35am ]</font>
