I regularly back my car against the garage at night to make sure I have all my lights. Last night I stepped on the brakes and no lights. Jumped pass the switch and they work fine. Changed the switch and they work but only under a lot of pressure. So under normal lite pressure, they don't work. Is this supposed to use a lighter pressure switch[if there is such a thing] or may I be having issues with the MC? Maybe the port is clogged? Is there a high volume IF I stepped on the brakes with no switch to maybe blow it out and IF I were to do this on my own, will it pull air into the system after I release the pedal?
Thanks for your time and any suggestions,
Karl.
Karl.
