I want to replace all the brake lines on my 67 mustang, its got 4 wheel wilwood disk brakes. Has anyone considered or tired to run all braided soft line instead of hardline down the frame?
I'm looking at classic tube and they have this stuff called Stop Flex, its DOT approved stainless flex hose.
You are limited to a "Max" length of soft line you can use for break lines.
About 8 - 12" soft tube per wheel MAX.
When you run your new lines, make sure none of the lines are higher then the porpotion valve / master cylinder.
I use 3/16" stainless hardline from Summit Racing. It can be double flaired and looks great.
