1963 Ranchero V8 / 4 Speed
Granada swap front disc set up. No proportioning valve.
I've converted the master cylinder to a dual resevoir style unit with no isuue until recently. I'm not getting a good return on the master and it's keeping the front calipers "engaged". Is it just the master cylinder going bad? Could bleeding the system help maybe? If I need to throw another unit on it, what would you suggest as far as bore size?
Thanx in advance!
Mike
Thanx in advance!
Mike
