The brake pedal went ot the floor last week in my 1970 Bronco - it has 4 wheel drum brakes with no power booster. The interior brake warning light did NOT go on.
No fluid was leaking from the wheel cylinders so I assumed a bad master cylinder. I swapped that out and as I was bleeding the brakes a rear wheel cylinder blew out - I'm suspicious this was the problem to begin with. So I replaced both rear wheel cylinders too.
Now the brakes work but my interior brake warning light is now ON?! I have rebled the master cylinder and brake lines twice now and the brake light will not go off. The truck stops OK but I havent gotton on the brakes very hard yet.
Any ideas why the brake light won't go off? Where do you think I should go from here? (trying to avoid a trip to a "real" mechanic)
