1 - 20 of 28 Posts
FE, Your "post whoring" wont be the same without your original name man!!!!!!!!
That's because I quit being the Post Whore...
I won't answer posts unless I have something productive or insightful to impart. Well, if the post is very silly and or funny I might put in a little hehehe or a snippet but that's it....
170
In 1961 the 170 became an option for the Falcon line. The original 1964.5 Ford Mustang used a 170 in³ (2.8 L), 101 hp (75 kW) version. The Econoline van and Ford Bronco received a heavier duty version with mechanical valve lifters. The 170 was dropped from production in 1972
200
The 200 in³ (3.3 L) was introduced in the middle of 1963. The 1965 Mustang came standard with a 200 in³ (3.3 L) that produced 120 hp (89 kW). The Mustang continued to use the 200 as its base engine until it was dropped in 1971. The 200 reappeared as the middle engine in the 1979 Mustang, now producing 94 hp (70 kW). This was the base engine again on the 1980 pony, but was dumped in 1983. The last year of production for the 200 was 1984.
<font size=-1>[ This Message was edited by: 64TBOLT2 on 5/18/06 11:10pm ]</font>
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
Try this, since there are issues with FordMuscle linkong to that particular place due to apparently an extreem prejudice...
Past the following without the spaces in the link.
h t t p : / / w w w.fordmustang.co.uk/fm-pix/index.php
Damn! That's an extreeeeeeeem prejudice if I ever encountered one... No linking outside FM ever I guess. Sorry for trying admin guys.
MDH... type in the following words as letters and go to page 7.
H Tee Tee Pee Colon Backslash Backslash Double-U Double-U Double-U Dot fordmustang Dot co Dot uk Backslash fm Dash Pix Backslash index DOT php and hit enter...
Can you manage to read all that?
1 - 20 of 28 Posts
