LOL, funny videos. All he had to say was "Do not run more fuel pressure than your carb was adjusted for." Duh. Will a carb go rich of you raise the fuel pressure? Yes. Always has. Always. With any fuel. That's based on physics - not oxygenates or lead. Can you run more pressure if you adjust the carb for it? Yes, to a maximum pressure based on the float and valve set. Again, that's always been true. Even Holley, BG, the OEMs, etc explain all this in their tuning info. Is this all because of oxygenated fuels? No.
Can a carb boil-over and flood the engine if they get too hot? Yes. Always have. However, that part is more sensitive with oxygenates, and is why you don't want to delete your thermal spacer that helps to keep the carb cool. Some even block their manifold heat crossovers to avoid it. We have said that many times here, it's nothing new, and is the only part of the video that has validity related to oxygenates. ShotRod64 has personal experience with this spacer/boil-over issue herself. Unfortunately, he sounds like he's trying to tie boil-overs to fuel pressure.
So why am I a bit on the grumpy side with these videos? Because he presents facts (richening, boiling, etc), but does not understand the link between them. Even the cameraman thinks you can run more fuel pressure if you just use leaded fuel. LOL. They even miss the point that customers want their carbs jetted down for economy (lean burn), and he thinks they mean jetted for CFM. What? Even if the customer actually asks them to "jet-down the CFM" they should understand what they really want and explain it to them - and everyone watching their videos.
Yes, this is what it's like if you throw a bunch of facts into a blender and pour it out. The parts are all there, just badly mixed-up. I will have to agree completely however, that advice from certain guys sitting at the local donut shop is often worthless, and occasionally harmful. An example being the original question in the first post and we have already explained how that is not true. On the other hand, this guy could prove his own theories wrong and come to understand the real issues - but he won't. He's the type that knows all and would rather argue it all than take the chance that he's mixed it up and would have to eat crow.
PS: Damn, I feel bad for all those boaters out there wasting tons of fuel running around with 13:1 at cruise. Holy crap. :frown:
