Hello im new to this board I have a 92 Mustang coup about 2800LBS Im running a 351 W with around 500 HP and a C-4 transmission it has a reverse manuel valve body , 5 clutch drum, Pro shift servoe, 6 pinion plannet hardened input shaft, deep pan this is a strip only car runs around 6.90's in the1\8
it was built about 5 years agoe and it just now started flaring up mainly in the 2-3 shift but not hardly at all one the 1-2 shift is it time for a rebuild its been run hard for the last 4 years atleast, and the fluid looks good to me smells normal or does the band just need to be adjusted it just started this all of a sudden.
