+1. You're looking for engine braking in
manual 1st gear, where the low/reverse band will be applied. This is a simple but important test as it can rule-out a handful of other issues. If you
do get engine braking in manual low, then the next two easy checks are:
- to verify your shift linkage is adjusted properly by the service manual procedure, and
- to loosen and properly re-torque your valve body bolts to spec, as too tight or too loose will cause VB operation issues.
Report back on the low-gear test and we can go from there.
PS: because it was lazy into REV before, signs are pointing towards low pressure in reverse. 1st gear test first.
