My C-4 will shift in all 3 gears when I first take off when I drive it for the first time. But then it wont go back in to the lower gears unless I give it a lot of gas. I think its the governor by reading other post. Can someone tell me where and what it looks like on the tranny?Also how to clean it? Thank You, Tony
The tail housing must be removed to access the governor assembly. The governor is retained by 4 bolts on the output shaft. you can use brake cleaner to clean the assembly.
