How much fluid pressure is one likely
to see in the tailshaft?
Enough to unseat an oil seal and push it
out of place? I would have thought that
any excess would have squeezed out
between the seal and the yoke.
Tailshaft bushing is in new condition,
by the way.
If you are talking about pressure inside the tail housing, none. If you are talking about inside the output shaft, line pressure. the only fluid that should be in the tail housing is what leaks by the seals and rings. minumal.
