what type of servo and is the oil return hole filled ? I only ask because if you are running a servo with the small lip seal removed and drain port plugged then sometimes you can have trapped air in the servo and it causes the intermediate servo to react sluggishly. Ive had squishy shifting 2-3 shifts that I had to drill the top of the servo cover and install a 1/16" npt pipe plug so I could fill the servo housing with fluid with a squirt bottle to displace the air. rock solid shifts after that . Just a thought and it really only applies to servos that are using stock servo bodies with plug drainback holes.
438 inch Dart block Windsor, AFR 225 heads, 271/
[email protected]" on 106 solid roller, 13:1 compression, Super Victor, crank trigger, 950 HP carb, external wet sump oiling, reverse manual C4, 4000 stall, 4.10 Dana 60, Nitrous. Stupid fast street '68 Cougar
<font size=-1>[ This Message was edited by: chipmechanic on 5/26/06 10:36am ]</font>
