I ran 'stock' clutches, (and even ONLY the 4 clutch setup) the last 2 years.
First year, (if you remember previous C4 posts), I had a loss of 2nd gear. (PA servo/kevlar band fixed that).
Anyway, didn't know that TCI used/utlized stock ford frictions/clutches in their kits. When you order a performance overhaul kit, ONE assumes it would have good stuff in it. NOT. In either case, where I"m going with this, is this.......I didn't add up ALL the passes on the trans the last 2 years, but there was alot. This is with those STOCK TCI frictions/steels. Saw a few heat spots on the direct. Other then that, they looked like new. You could still read the FORD part numbers (in ink I'm assuming), on the frictions......... Wonder what kind of heavy hitter it's going to be this year with reds in the forward, and the new 6pack in the other?
