I have a pan fill c4 that's in need of a rebuild and higher stall converter. I ran across a good deal at a swap on a new break-away converter, but when I got home and checked the part # I found out I bought a case fill converter
I have a bellhousing and flex plate from a case fill, will these go onto a pan fill so I can use this nice new converter?
The case fill bell and flexplate can be used on the pan fill case.Just bolt it all up to the pump on the pan fill case.Make sure to use the longer pump bolts though.Also make sure the convertor and trans input shaft splines all match and as always ensure you have the correct convertor clearance when all is bolted up..
