Ok, got my new c4 all together 26 spline pan fill w/ TCI Streetfighter 3000 stall. Also have a B&M cooler, no cooler in radiator. I put 1 qt in the converter, and put 4 in the tranny before I started it up. After I started it I added 3 more qts. Now it says its way to full? About 3in up the dipstick. Thats only 8qts. My manual says it will hold 10 qts, and I expected it to hold less with the smaller (10in but the one that was in there was 11in) converter, but to be this full? I ran it through the gears while on jackstands, and I drove it around the block. All gears seem to work fine. If I drive it more will the fluid level go down? Is the dipstick right (case fill stick full line is 3in up and pan fill stick full line is about 1 3/4in up the stick)? Should i take fluid out?
