How much fluid do I need to put in if I drained the pan and removed the valve body? I had to fix a leaky shift shaft seal, and I dunno how much juice I need to put back in, I just need a ballpark amout.
4 quarts should do it. I just had the valve body out of mine and added 4 qts when I put it back together and it's close to being right.
I believe that if you go to Performance Automatics site they have instructions listed there for valve body R&R and it states to refill with 3qts and then check level after running it to temp.
